I purchased some Runtal base board heaters a while ago. I am trying to install them into an existing multi zone fin tube system. In the zone I am trying to install them I have fin tube before the Runtal and some fin tube after the Runtal (these are all separate rooms on this zone). I feel like I need some sort of temperature controlled diverter so that I can balance the Runtal with the other fin tube that come after in the flow. Runtal makes the temp control valve but I need one that can either be put in my basement with a remote temp sensor in the room with the Runtal or connected to the Runtal inside the room and I guess I would run another pipe to the diverter bypass. The bypass would go directly to the next room where there is fin tube. Can I do this manually with a mixing valve or what is the right thing to use?
To hopefully better illustrate my system, the zone I am working on has the following water flow path:
boiler -> Dining Room (fin tube where thermostat is) -> Foyer (fin tube) -> Office (where I want new Runtal) -> Bathroom (fin tube) -> return to boiler
I guess the other way to do it is to plumb a new zone to just the office and bypass the office on the zone described but that might be difficult because I would need a new manifold with more zone valves.
Thanks for any info.
