I have a three-wire cable feeding a 60A sub panel from the main panel. Will a separate wire from the main panel to the sub-panel suffice for the ground or neutral in the sub? Separation of ground and neutral or bonding will take place in sub panel.
    If the wires are in metal conduit, then the conduit is used for ground. I am assuming this is for a simple hot, hot, neutral North American system.
    Sep 28, 2022 at 13:03
    If the sub is in a separate out building, it needs its own grounding rods.
    Sep 28, 2022 at 16:51
I’m going to assume you don’t have separate wires in conduit since then you could just pull an additional wire.
The problem is that a neutral wire must be in the same cable as the hots. No exceptions. If your cable has a green wire or a bare wire, that must be ground and cannot be reassigned as neutral.
On the other hand, if you somehow has a red-black-white cable, you would be allowed to add a green or bare wire separately. It doesn’t even have to follow the same route as the main cable.
  • Additional note: If there were separate wires in metal conduit, the conduit could be the ground. (as noted in comments on the OP, too.)
    Sep 29, 2022 at 14:53
Also if you have a sub panel that is next to your main panel you do not want to bond the neutral and ground. This will cause a draw on any ground in your home because the neutrals and ground will be essentially on the same 'return' power. As stated before if the sub-panel is in another building it needs it's own grounding rod.
  • It doesn't matter where the sub panel is, it should NOT have a neutral-ground bond.
    Sep 30, 2022 at 13:01
