I'm located in Chicago and live in a one story home (no upstairs just basement) and just had an electrician come to add an outlet for a dishwasher and put the refrigerator on its own circuit. They decided the quickest way was to run an additional conduit line horizontally in order to use some existing wire and therefore had to put holes through multiple studs. The electrician kept acting like the holes he made were no big deal and they do it all the time but from what I read of the building code, the holes are certainly larger than I believe is allowable and closer to the edge than allowable and I'm worried about the structural support of the home now.
(https://codes.iccsafe.org/s/CHIBC2019P5/chapter-23-wood/CHIBC2019P5-Ch23-Sec2308.5.10)
2308.5.10 Bored holes. Bored holes not greater than 40 percent of the stud width are permitted to be bored in any wood stud. Bored holes not greater than 60 percent of the stud width are permitted in nonbearing partitions or in any wall where each bored stud is doubled, provided that not more than two such successive doubled studs are so bored. The edge of a bored hole shall not be nearer than 5/8 inch (15.9 mm) to the edge of the stud. Bored holes shall not be located at the same section of stud as a cut or notch.
The first and second photos are what was cut out from a load bearing stud and the third photo is what was cut out from a non-load bearing stud. Any ideas on what I should do? Is this acceptable? Do I demand a refund or fix? What is the fix for this? I'm unsure if a sister stud can be added or not and it would be a huge pain to have to put in a completely new stud.
