Nothing is removable at the top, and it does not have external fasteners. The bottom bezel unscrews but the globe or housing won’t drop out. Cannot believe I can’t figure it out...
@nobody deletes "wrong" answers unless they're unsafely wrong. This was a good assumption and other lamp assemblies could come apart this way. Up voting the "right" answer will help it float to the top so people see it first and don't attempt this "wrong" thing until after they've looked and determined that the "right for this particular fixture" isn't the right answer for their fixture.– FreeManSep 29, 2022 at 13:07
Please put the "answer" photos in the answer. I just looked through the question and without looking at the edit history, there's no way of knowing which pics you've added and none have any obvious screws showing nor any hand-drawn red arrows showing where the screws are. Additionally, there's no need to edit "solved" into the question, either. The fact that there's a check mark on this answer tells the world that it's solved - that is called out in the tour you took.– FreeManSep 27, 2022 at 14:01
Wow. I've had to stare at that pic for a while to find the screws. Not shocking that you couldn't find them right away.– FreeManSep 29, 2022 at 13:06
