I'm installing a ceiling fan into a living room with no overhead lights. (1921 house in Minneapolis). The ceiling in the adjacent room is accessible thru a (ridiculous) drop ceiling installed where the plaster was failing. That's another project. I have the new electrical ready to fish from the adjacent room between joists. When I drilled the hole for the new fan I realized that the ceiling is actually drywall that has been attached to 2 layers of 2x4s which as far as I can tell are attached to the intact plaster ceiling. Trying to access the joist space above the plaster I drilled a smaller hole in the same hole (shown in image) and now I'm hitting the actual ceiling joist. I can poke around within my 4 inch hole and hopefully figure out where to drill where I won't hit a joist.
Am I right in thinking this is the right approach? My husband was encouraging me to run the wire between the ceilings (which to me screams bad diy) and I'm not convinced it will be easier. Once I get into the joist space I can see I have an unobstructed run.
As an aside, any ideas why they would have done this? It shortens the room by 4 inches (1 1/2 per 2 x 4 plus 1/2 inch for the drywall. It seems like overkill to me? We moved in in 2004- I'm guessing it was done pre 1990 when the owners before us moved in.
