I have a chest freezer with several holes in its metal lining, as pictured below. Can I just slap some HVAC tape over these, or is there a better material or approach? Do I need to worry about filling in the insulation, and if so how?
Larger holes in freezer wall:
Smaller holes in freezer floor:
Whole freezer, for scale:
  • I think HVAC tape (rated for say -25F) would work. If not, and it comes off, it's going to look like hell anyway. It seems the ice pick used was pretty dull! Sep 16, 2022 at 14:04
    you probably want to fill or insulate the void behind the path to keep air out; otherwise it can condense can cause mildew inside the unit, or in extreme cases, drip and damage the floor. Even a wadded up plastic bag would work; just something non-porous to fill the space so that air cannot.
    – dandavis
    Sep 16, 2022 at 20:42
refrigerated truck compartments are basically made of the same stuff as your freezer body.
So there's a method designed for reparing foam filled aluminium panels.
It seems to be squirt-foam to fill the void, and then after the foam has set, a two part adhesive to glue an aluminium patch over the hole.
product reccomendations are off topic, but a search on "repair foam filled aluminium panel" gets plenty of results.
You might cut some pieces of Aluminum sheet to fit and affix with silicone adhesive.
