I have this new bath drain. It comes with two optional tail pieces. One uses outer threads and a nylon washer. The other uses fine inner threads. The drain basket is threaded for either one.
Are there any pros and cons to the two tail pieces? The inner-threaded one seems more secure to me. Stronger, fewer parts.
How do I seal the inner threads? They are very fine, they cannot use Teflon tape. Should I use silicone lubricant? Pipe dope? Someone told me to use silicone caulk, but that doesn't sound right.
There is no guidance in the instructions. The basket and all its mounting parts is from one kit, and it's threaded both ways for flexibility. The two pipes are from another kit, and they are both provided ... for flexibility. So I have lots of flexibility but no wisdom.
