An outdoor flat steel door is to be painted:
Any suggestions and their reasons for the type of paint to be used is appreciated. Thank you
A brush or roller will get paint on it but? I would recommend although you did not mention it spray painting it. Your favorite box store will happily sell you a can or to of whatever color you want for not to many $$$. In the end a better finish and the clean up becomes easy.
With brush, you will have stripes, and with rollers you will have stipple. However this can be reduced.
Search "$99 Rust-oleum paint job". (think Rustoleum as found in gallon cans, not spray cans). The target is cars, but they display good techniques for doing "almost spray-like" finishes with alkyd paints from brush and roller. Of course working with a flat door that is horizontal while painting will only make it easier still.
Working with latex/emulsion is more challenging but the concepts may help: ultra-thin the paint so gravity helps it lay flat, and plenty of coats.
I can get "spray-like" using that technique. However I cheat a bit, and use 2-part LPU marine paints which have special B-parts formulated to deliver "spray-like" finish with brush and roller.
I never succeeded painting a perfectly flat surface with brush without seeing the stripes.
I blame it on paint, the brush, but never on my painting skills.
In that situation I prefer a roller. Actually a foam roller.
