I currently have two ceiling fans controlled by two switches. One switch operates the lights for both fans. The other switch operates the fans on both fans. I want to convert this set up to two lights operated by one switch.
The fans were wired up with four wires - Red for lights, Black for fans, white for neutral and ground.
The switch set up has me stumped! See photo below. A couple of things to mention: The switch on the left is for the lights and the switch on the right is for the fans. 4 sets of wires enter the switch junction box. All of the white wires are pig-tailed together. Some of the blacks are pig-tailed together and paired down to one black. The same black flows from the left switch into the right switch and then back out as black. What is going on here? How should I convert this setup to a single switch to turn on two sets of lights. Currently, the lights in the ceiling are wired black (light) to black (ceiling) and white (light) to red (ceiling)
