I'm trying to determine the temperature rating of my service entry cable, so I can then determine its ampacity.
It is marked:
Type UD CONALCO-S XLP POWER CABLE 600 VOLT 1/0 AL 1974
So I'm assuming its type is either UD or XLP. However neither of these are listed in the CA Electrical Code section 310.104: https://up.codes/viewer/california/ca-electric-code-2019/chapter/3/wiring-methods-and-materials#310.104
Is there an equivalent type that can be used for determining its temperature rating? If not, how should the temperature rating be determined?
Background [Updated]: This is an underground service entry to the main panel for a 1000 sqft house. The main breaker in panel is 100 amp. I'm trying to figure out whether I can either upgrade the panel or upgrade the main breaker in the panel without replacing the service entry. My understanding is that I need to start by determining the ampactiy of the cable, which starts with its temperature rating. But if there's a different way to answer the ampacity question I'm all ears. I do know about the '83 percent' rule, and may make use of it.
