There are four small spots of sealer on an aluminum garage door. I'm looking for something that will remove it without damaging the door surface.
    gasoline would work
    – Traveler
    Aug 30, 2022 at 19:49
  • Gas worked great. It almost instantly dissolved the oil the moment it touched it. No damage to the door either. I used a little more gas just to clean the gas can itself.
    – Zannon
    Sep 6, 2022 at 23:12
  • Let me make that a answer, so you can reward me.
    – Traveler
    Sep 6, 2022 at 23:55
Sometimes simple solution works best.
In your case I would recommend to use some gasoline.
There are other solvents, but I found the gasoline works great.
    Gasoline is a crappy choice of napthatic solvent -- they invented safety solvents for a very good reason! Sep 7, 2022 at 2:01
    Gasoline makes a fantastic solvent (as is lighter fluid). It has some unfortunate side effects that should cause one a bit of pause before using it.
    Sep 7, 2022 at 12:41
