If using ground contact timbers and joists for the structure of a deck (in this case a treehouse), is it a good idea to use joist tape to help protect against rot over the course of many years, or does it being ground contact render it not helpful.
What is "joist tape"? Are you using it on portions where the wood touches the ground or just in general? Please edit to provide some more clarity.– FreeManAug 26, 2022 at 13:03
Huh... apparently joist tape is sticky flashing applied to the tops of joists to protect against water infiltration and seal around screw holes. TBH, it sounds like a marketer's dream product - use the same kind of sealant tape designed to seal doors & window flashing and come up with a new use for it. IMHO, it'd be optional in all deck installations, but I'd wait for someone with more experience to chime in.– FreeManAug 26, 2022 at 13:07
Also, just stumbled across this highly related question.– FreeManAug 26, 2022 at 14:24
Add a comment
