24
A lot of questions have been asked about how to locate a leak in a roof, but you can only locate a leak that you know exists, and the first noticeable sign that there is anything wrong might be drywall damage in your living space.
By this point, the drywall is obviously already damaged, and the roof decking or other behind-the-scenes parts of the house might also have significant damage, so you need to pay not only to repair the leak but to clean up the damage it caused.
If you knew about the leak when it first started, you might be able to repair the leak early enough that it wouldn't have time to damage anything else.
How can you monitor or screen for leaks or possible leak-causing damage in a residential roof, so that they can be fixed before they cause water damage?
18
    It doesn't have to be an integrated electronic alert system; maybe there is a commonly recommended regimine of manual inspections of attic spaces, or somebody I should hire who flies over the roof every year with a drone?
    – interfect
    Commented Aug 24, 2022 at 14:06
    If a shingle roof(quite common) you inspect and fix any damaged shingles as soon as possible.
  • 4
    Looking from the outside is probably the most common thing to do. Inspection from inside the attic - for some that is easy, for some nearly impossible. Commented Aug 24, 2022 at 14:06
    @crip659 How do you know that shingles need inspecting, though? Should you get up there and look after every storm?
    – interfect
    Commented Aug 24, 2022 at 14:08
    I discovered certain leak points when I was investigating why the woodpecker started hammering on the siding in certain points. Sure enough it knew there was moist wood inside even though there was no visual evidence of damage on the siding, but the roofing membrane had pulled away from the flashing in the upstream vicinity.
    – Ian W
    Commented Aug 25, 2022 at 4:45
5 Answers 5
17
I go up into my attic about once a month (or after we get a heavy storm) with a good flashlight and give everything a visual inspection. Specifically, I make sure I'm very accustomed to the way that the roof is supposed to look. Then, in the handful of cases where I've had a small leak, that leak stands out as pretty obvious.
Leaks generally start small and work their way up. When water first starts seeping in slowly, a lot of it gets absorbed by the wooden roof decking, the rafters, or if it drips down, by the wood on the attic floor. Wet wood is much darker than dry wood (insulation usually looks different as well), so I've always identified leaks by noticing the dark spot that wasn't normally there. If it's a leak, it'll usually be damp to the touch as well. You're technically not detecting the leak before it happens, but with regular inspections you can notice it before it has a chance to cause any real damage or make it through to the drywall. This is where it's important to know what your attic looks like under normal conditions, so you'll know that dark spot has always been there but that dark spot is new. Most leaks occur around places where there's already a hole in the roof (vents, chimneys, satellite dish mounts, etc.) so pay particular attention to those areas.
Again, it's not a perfect solution, but it's easy to do, free, only takes about 10 minutes, and is fairly effective.
    Of course, walking around on a roof could also lead to damage, eg: cracked shingles, or popped nails pushing through membranes, etc. (I know you are in the attic looking up, not on the roof).
    – Ian W
    Commented Aug 25, 2022 at 4:35
  • 4
    @IanW I don't see him suggest to get on the roof anywhere, but rather into the attic :)
    – MiG
    Commented Aug 25, 2022 at 5:01
    @MiG, Noted in parenthesis, more of a general clarification to be careful. I know I damaged my roof by walking on it to inspect.
    – Ian W
    Commented Aug 25, 2022 at 5:49
  • You can do that as long there is enough hight for you to fit in.
    – Traveler
    Commented Aug 26, 2022 at 1:23
Roof leaks are caused by many different things. For example:
  • Shingles or tiles: Cracked, broken, missing, worn
  • Flashing: Loose, broken, missing, poorly installed, worn
  • Gutters: misaligned, clogged
  • Ice dams
  • Flat roofs: insufficient or poorly spread gravel
  • All roofs: end of life
Most of these are difficult or impossible to detect directly. You need experience and expertise to be able to tell when normal wear leads to the need for spot repairs, total replacement, or when there are abnormal problems.
I know this isn't much of an answer but I think it's a really good question and unfortunately there isn't a magic answer. The best I have is: Read up on the particular kind of roof you have, know what KINDS of things can go wrong, understand that water travels, inspect it regularly so you are in tune with what "normal wear" looks like, and watch for stains or other signs of leaking. Have it professionally inspected once in a while, and learn from the person you hire to do that.
  • It is not much of an answer, more a lecture. But people seem to like it.
    – Traveler
    Commented Aug 24, 2022 at 20:23
  • We had a ridge vent that let snow blow into the attic. Didn't know it until it started to melt and saw a wet spot on the ceiling. Went into the attic and started filling a bucket with snow and passing it down to the SWMBO who dumped it into a bathtub. When the tub was full she asked how much more there was. Sigh.
    – HABO
    Commented Aug 25, 2022 at 2:53
    Most of these are difficult or impossible to detect directly amen to this... i've had roofs leak where I knew there was water coming in, a lot of it, but looking directly at the roof outside I had no clue how it was getting in.
    – Michael
    Commented Aug 25, 2022 at 3:03
A visual inspection once a year or after a severe storm. A great pair of binoculars could save you trips to up on the roof. Look for any shingles that have lifted or are torn. Also look for nails that have started to come out, raised up from the singles, especially on the saddle shingles on the peaks. Once you detect flaws, fix them promptly. Unfortunately, most leaks are found by noticing a water stain on your ceiling. What you do then is put a pan in the attic over the spot to stop the water from soaking more into the ceiling and then start investigating where the water's coming from.
  • A great pair of binoculars is a great idea ?
    – Traveler
    Commented Aug 24, 2022 at 20:24
Whether you have a tiled roof, a sloped one or a flat one, the roof’s surface can suffer from persistent moisture which leads to damage.
Many causes for leaks, and none is predictable but some are obvious like Shingles: missing, cracked, broken, Flashing: Loose, broken, poorly installed, worn, Gutters: misaligned, clogged.
The challenge is by the time you can see it, it has already progressed. The leak damage is not always directly under the problem, it might leak somewhere else .
You can detect any leak well ahead of time using a thermal camera, that professionals use.
From inside (under the roof),
Or without climbing on the roof from outside with drone.
Additionally it could expose roof insulation problems (hot spots).
Not only the roof: Infrared is helpful for all home insulation checking. On Hot days with AC running full blast it can detect your hot spots. On Cold winter days it can detect your leaks.
If you are looking for renting or buying: Some typical average costs are $250-350 for regular visual inspection, $550 for an infrared drone roof inspection. Slate and tile roofs are harder to inspect and it costs an average of $800 for large roofs.
DIY visual inspection: If you do it from under the roof, you can only reach about 1/3 of the area (where you fit in). If you do it from outside (walking on the roof), you must use safety line or risk you life.
  • Some large hardware store chains have tool rental services. Renting a thermal camera for an hour 2-3 times a year could be an even less expensive option.
    – bta
    Commented Aug 25, 2022 at 2:21
  • to be clear, you aren't talking about buying the camera when you mention ROI, right?
    – Michael
    Commented Aug 25, 2022 at 3:05
  • @Michael that is a individual choice, rent or buy.
    – Traveler
    Commented Aug 25, 2022 at 3:11
  • well I ask because I read it to mean "buy" until I got to "$550 for an infrared drone inspection" which makes it sound like you wouldn't be buying and probably not renting, but paying somebody else to check it with IR for you
    – Michael
    Commented Aug 25, 2022 at 23:14
  • @Michael the $550 was what you pay for drone inspection, it could be also great excuse to get a drone :)
    – Traveler
    Commented Aug 26, 2022 at 1:20
Something I've learned the hard way is to get your roof inspected for the proper nailing pattern.
Nails should never fall in between butted shingles; I think they're supposed to be at least an inch from the butt but don't quote me on that.
