I have a Generac GP8000e generator that I plan on back feeding the main panel of my home with the portable generator, power inlet box L14-30a and breaker. First, I will install an interlock between the utility main breaker and the generator back feed breaker. I will only use the L14-30 receptacle to power my home.
- Do I need to ground my generator with 8’ rods etc.?
- Do I need to remove the neutral ground from my generator since my main panel already has that?
