I live in a one bedroom apartment. It's a duplex but the other side is vacant. In the hallway there is a very small closet that holds the HVAC. I have a Goodman model capf1824a6db.
All summer the apartment has had a hard time staying cool and/or cooling down. The electric bill went up significantly. But yesterday I opened the AC closet and it is noticeably cooler in there than anywhere else in the apartment.
I changed the air filter this morning and it made no difference. I have also noticed that even though I do have cold air coming through the vents, it is not a strong airflow.
I've let the office know about it and they said they'll put me on the list. There are 6 people ahead of me on the list and only one maintenance person who can work on air conditioners or heaters. So I'd love to know what the problem is and if I can fix it myself instead of waiting for the maintenance guy to get here. (Took 9 months to get maintenance to come fix my oven. So I'm not a fan of waiting on them) oh and I'm not sure if it is possible for me to check the ducts in the attic because it's a shared attic and this side of the building doesn't have access to the attic. The other side is where you get into the attic and that side caught on fire a year ago and hasn't been fixed or even cleaned.
  • are the air intake (filter) blocked by furniture ? where are the air vents located ? ceiling, floor, walls
    – Traveler
    Commented Aug 17, 2022 at 19:46
  • what is in the cabinet is only one part of your AC. That one is called evaporator coil. It has a Fan and cooling coil. It sucks the air from your apartment and cools it over the cold coil. The second part of the AC is outside. It has a compressor and big fan. It is very noisy. Your problem might be the coolant is low (on the outside unit), and Icing. Open a cover on the indoor unit and take look at the coil. Is it Iced ?
    – Traveler
    Commented Aug 17, 2022 at 19:59
  • The vents are all on the ceiling. There's nothing blocking any of them. The air intake has nothing blocking it either. The filter for this unit is underneath the unit. In the closet the unit sits on a shelf type surface that has a hole in it that's the size of the bottom of the unit. So under the unit where the air intake is, it's hollowed out. So there nothing blocking that either. I just had coolant put in in June. And when I opened it up this morning to look at it there was no ice on any part.
    – Alexis G.
    Commented Aug 17, 2022 at 20:05
  • And I've looked at the part outside as well to see if there's anything blocking it or crowding it and there's nothing.
    – Alexis G.
    Commented Aug 17, 2022 at 20:07
  • You had coolant refilled ? did they test for leak ? When looking for icing make sure you see the cooling coil where the ice could be. Your symptoms indicate, Low coolant, iced coil, which would reduce air flow, unless a duct is disconnected,
    – Traveler
    Commented Aug 17, 2022 at 20:27
Check all around the AC unit for leaks, breaks in the duct work, the cool air has to be coming from somewhere. If there's a register vent in that closet, close it and see if it makes a difference. If you do fine some cool air leaking, you could seal up the opening with some foil tape or AC mastic. That's about the limit you can do to fix it if it's a rental you're living in.
  • What's a register vent??
    – Alexis G.
    Commented Aug 17, 2022 at 23:39
  • @AlexisG. it's a vent that cold air would be blowing out of.
    – JACK
    Commented Aug 17, 2022 at 23:56
