After working fine for 3 years the door on the washing machine (Zanussi Lindo 100) got stuck. I was able to take the machine top off and manually pop it open from behind. It seems that the door has moved over (?) and the closing mechanism is not aligned. So when the door does close it is too far over that the hook stays engaged when opened:
you can see the black area where the lock is hitting the wrong area
I took the door off the machine, and it was able to open and close fine, because it was free to exit from the correct position. So I basically left the screws (red 1) loose so the door has the freedom to move over a bit to exit the lock. The hinge screws (green 2) are very tight and I have not interfered there.
There does not seem to be any leak due to the loosening of the door. But it is not fixed and there must be a way to get the door to open and close properly with the door tight on. How do I move the door over.
Would be to get it to the left a bit from this pic:
