I have a new 100amp rated sub panel, grounded with a new copper rod in my shed 50 feet from main breaker box, with 6/3 as the feeder to the sub panel. I’m installing a hot tub. I do have a 50amp breaker box between the shed and approximately 6 feet away from the tub. Can I use 6/3 to run from my sub panel to the 50 amp breaker box for the hot tub?
I only have 4 outlets I use in my shed all on one 20 amp breaker. I just want to know if I can run power to my hot tub with the 6/3 off my sub panel, with my sub panel being powered by 6/3.
