I'm also looking for the control pull chain switch to control the 3 speed fan. Can anyone anyone help, seems the description for most switches out there don't give enough detail.
I found this info in another question on this site. It's the same Hampton Bay ceiling fan I own.
I need a new capacitor. Do I need one with exactly the same specs? I find ones with out the matching voltage.
Here is what I have, though I can't confirm the CBB61 series, that was in post I am using as reference.
fan: Hampton Bay EF200D
CBB61 series capacitor, 4 wires:
    black: common
    blue: 3µF, 350V
    red: 3.5µF, 200V
    yellow: 6µF, 200V
3-speed, 4-wire pull-chain switch with terminals L, 1, 2, 3
The capacitor has component # E175257
Can anyone recommend a capacitor that will work?
Thanks,
Dave
  • You can find it on ebay, amazon, ect
    – Ruskes
    Aug 5 at 23:53
  • Not the exact specs: 3uf 350v, 3.5uf 200v, 6uf 200v 4 wire capacitor. Aug 6 at 0:09
  • ignore the voltage, it is only for maximum indication, you will newer exceed 120 Volt
    – Ruskes
    Aug 6 at 0:39
