We are experiencing some water leaking from the PVC pipes in the front lawn. Is this normal or do we need to address this issue? The water does not appear to smell but we can tell it’s been happening for sometime since there is green algae forming on the rocks.
  • Looks like some drainage system that's clogged. Remove that cap and see if you can see more. You might have to snake it.
    – MonkeyZeus
    Aug 5, 2022 at 15:48
  • What size is the pipe?
    – JACK
    Aug 5, 2022 at 15:50
  • Probably the end of a soakaway connected to downspouts or sump pump outlet. Where is it, relative to your house?
    Aug 5, 2022 at 16:00
  • what is that white globe
    – asinine
    Aug 5, 2022 at 18:51
