I am going to add a new 240v outlet, but I cannot find the ground bar in the panel. It looks the ground line is connected to the neutral bar(white line) directly.
See panel photo below
panel Panel
  • If putting a new circuit in a garage and will use a receptacle/outlet, will need to have a GCFI. There are probably a few other places in the home/house that also requires GFCI protection.
    Aug 5 at 0:19
If this is the main panel, then the panel maker just combined ground and neutral bars into one instead of having two separate but bonded together bars.
Quite a few panel makers will have two bars, but they will be connected together, either by a wire or the metal of the panel itself.
In sub panels(extra panels) then you need separated and unbonded(not connected together) neutral and ground bar.
