I'm running some THHN wires from surface-mounted receptacles in a finished kitchen up the surface of the wall and into the attic. Surface run is wiremold 700 raceway, conduit in attic is flex. I've got the special wiremold-to-1/2 inch standard knockout fitting and plan to put a 1/2 inch male fitting on the end of the flex to attach it to the wiremold fitting. The THHN inside will be unbroken from receptacle through the wiremold and through the flex to a metal junction box in the attic.
Question: Can I just run the surface wiremold up to a hole in the ceiling that my flex male fitting is sticking out of, without installing a portal of some sort in the ceiling? The wiremold and its fitting will be secured to the wall, and the flex once through into the attic will be appropriately strapped.
Edit: To clarify, I will have an unbroken conduit run from receptacle in room to junction box in attic, although transitioning from wiremold 700 surface raceway in the room to flex through the ceiling and in the attic. Do I need to install anything special for the flex passage through the ceiling?
