enter image description hereenter image description hereI am replacing a kitchen ceiling light/fan in a house I just recently purchased. It has two separate cables coming into it. Each contains a red, black, white, and ground wire.
The box is controlled by two switches that are at opposite sides of the kitchen.
The fan kit has a black white blue and ground wire.
Unfortunately I didn’t pay attention how it was wired prior when tearing out the old fan.
  • With the breaker still off, open up the switches and take pictures, so we can see how the switches are wired. Were those wires connected like that before?
    Aug 3, 2022 at 16:58
  • I will send pictures if the switches when I’m off shift. But yes that’s how it was wired when I pulled the fan down and finally looked at the wires
    – Dan
    Aug 3, 2022 at 17:25
  • Two single pole switches? Do you mean that both switches must be off to turn off the fan?
    – DoxyLover
    Aug 3, 2022 at 18:58
    whenever i see this type of questions i always wonder; wouldn't it be faster to just meter all 4 permutations than to write up a question and wait around for answers?
    – dandavis
    Aug 3, 2022 at 19:33
That looks like a switch leg to me. The black and white connected.
This takes the power down to the switch on the white as hot all the time.
Jumper that white to 2 switches then you can bring back the power on the black for 1 switch
The second switch is on the red wire.
Connecting devices at the fixture is the red or white to the fan and the other to a light. This is an inexpensive way to provide for 2 devices with 1 cable.
Unfortunately code outdated this application in the last update as on newer homes a neutral is required in 1 switch box (in the case of a 3 way one side requires a neutral).
But this is what I think you have from the 2 switch comment and what I see at the fixture.
  • So where would I connect the black white and blue wire from the fan kit
    – Dan
    Aug 3, 2022 at 23:54
