I currently have a central AC system. I'm looking into replacing it with a variable speed one. I've been told that if I'm replacing it anyways, I should look into getting a heat pump instead for a bit more so I get an alternate heating option.
Looking at my thermostat wiring, it's only a 4-wire cable and they're all used up. Is a heat pump even an option for me to consider?
  • How is your heat currently controlled? Aug 3 at 11:39
    Are you OK with replacing your existing thermostat? Aug 3 at 11:43
    Thermostat wiring can also be replaced...
    Aug 3 at 12:39
  • Typical heat pumps generally require 8 conductor cables to the tstat. You'll almost certainly need to replace the tstat as well and maybe some upgrades to the air handler. Aug 3 at 15:49
  • @ThreePhaseEel Yes but I got a Honeywell T9 which I think supports a heat pump.
    – Jack
    Aug 3 at 18:08
