Today I was doing some due diligence to open up an interior wall on the first floor or 2 story house built in 1968. The wall runs parallel to the joists so presumably is a non load bearing. When I cut a small part of the ceiling near the wall, I noticed that there is 2"x7"(exact dimension) lumber resting on the top wall plates seemingly spanning the whole span of the wall (I am not sure since on top of this lumber are resting blocking on either side of where I cut the ceiling). It looked like the lumber has a tongue as well - so might be the same type of lumber used as the subfloor in the house. The cross section of the wall and this lumber would look like a "T". The 2nd floor seems to sit directly above the blockings.
With my limited experience - I have not seen such an arrangement before. I am wondering if somebody can help me identify function of this 2x7 plate? It also seems to have a cut in between so it's not a continuous piece but two pieces butted together. FWIW - I had seen similar houses in the community with a pocket door in the exact wall... that along with the fact that it ran parallel to the joist had me convinced that this was a non load bearing wall. Now I am doubting it...
  • 23
    A picture would help immensely.
    – MonkeyZeus
    Aug 3, 2022 at 11:46
19
That's standard practice to create backing for drywall (or plaster lath) where walls are parallel with ceiling framing members. It's reasonable that the carpenter would've used extra subfloor material as it was readily available and of lesser grade (less expensive) than other material. It's also expected that several short pieces were used, as this is a good way to make use of scrap.
image source
image source
