I spackled this wall, gave it two coats of primer and the first topcoat of paint. Now I noticed when the light hit it this morning that I neglected to smooth down this patch of spackle adequately. It's raised up above the level of the rest of the wall and looks terrible.
Would light sanding before the next coat if paint solve this or make it worse?
Latex paint on sheetrock. The spot is about two inches wide.
