This is SELV so the rules are very relaxed compared to power wires.
What type of steel wire rope should I use ?
One that's strong enough and sufficiently durable, if you're near the coast I would recommend stainless steel for all parts of the support rig, if you're outside the salt-spray zone galvanised steel will list decades, and the extra cost of stainless is probably not justified.
Can you show me a detailed schematic of the installation of the steel wire rope ?
attach the anchors to structurally sound parts of the buildings, use cable thimbles on the ends of the wire.
raise the wire and tighten the turnbuckle.
do a search on electrical catenary.
How can I install on the steel wire rope the internet and tv cables ?
There are many options.
eg uv-resistant cable ties (black nylon, or stainless steel) or you can attach rigid plastic conduit to the caternary wire and put the signal cables inside that. (reccomended if you have wildlife that likes to eat cables)
All cables should be rated for use in wet locations (even if you use conduit)
