I've planning to mount some shelves using these IKEA Lerberg brackets IKEA lerberg brackets
Should I mount them to the wall or the shelf first?
In my opinion, it would be easier to do by yourself if you mount the brackets first.
Just make sure they are level with each-other.
You may not have a choice if the shelf locks in by sliding forward. If that's the case, you mount to the shelf first and then hang it on the wall. Otherwise, the wall blocks you from installing the shelf. And even if it's not necessary, you may want to do it that way to get the shelf tight to the wall. Mount the brackets 1/8" or less from the back of the shelf, so the shelf touches the wall just before they do. Then, after hanging, when you tighten the screws on the wall, the shelf will get pulled tight without any gaps.
    It looks as if the keyhole slots for the shelves have the narrow slot in the back. In that case, the shelves lock in by sliding back, so mounting the brackets on the wall first should work. It also has the advantage of not having to lift and support the shelf while you are attaching the brackets.
    – bib
    Feb 19, 2013 at 13:25
  • Thanks @blb, I checked the zoomed image on the ikea site and it looks like you're right, the shelf does slide in from the front. With keyhole attachments, supporting the shelf isn't as big of a concern to me, but you're right and there's no need to make it more complicated if a tight fit isn't necessary.
    – BMitch
    Feb 19, 2013 at 18:17
I would mount the shelf onto the two brackets then take the entire shelf and mount it to the wall, first screwing or nailing one side ONLY the top screw and then leveling the shelf then screwing in the second bracket ONLY top screw.
Once it is level screw in the other screws.
You can use a level if you have one BUT do not only use a level, step back and eyeball it, then affix it permanent to the wall. Using only a level will not ensure that the shelf is actually "level" in the room as it is highly unlikely that your room is perfectly level (i.e. the floor may not be 100% level ;) )
