I want to hang a vent hood on the wall and this wall has electrical and gas pipe between studs. It only has enough space for 3/4 plywood blocking. Is this adequate? Thanks
    You will need a bit more info than that. A picture of your conditions is needed including the hood. That said, most hoods I have set, was able to use just the studs in the walls.
    – Jack
    Jul 23, 2022 at 13:59
    How will you ensure that the screws you use to attach your vent hood to your 3/4" plywood don't go all the way through it and into the pipes behind?
    – brhans
    Jul 23, 2022 at 14:24
    @brhans use 3/4" screws? :) Jul 23, 2022 at 17:10
  • How much does the range hood weigh? How is it meant to mount to the wall? Does it really require blocking, or does it have some sort of adjustable rails or brackets that can accommodate various stud locations -something like a TV wall mount?
    – SteveSh
    Jul 23, 2022 at 21:30
Yes. Floor assemblies can use 5/8" plywood for joists 16" oc. Floor assemblies carry people, pianos, fridges, etc. 3/4" plywood will certainly hold a range hood. You'll need to use enough fasteners.
