I'm trying to install an IKEA Solklint and the wires do not easily match up with my existing fixture.
  1. Where do I attach the ground wire? Will any screw be fine?
  2. Is the red or white wire the live one?
Click to embiggen
Ground
The ground wire should be attached to the metal box, ideally by a screw that is located in the back/top of the box. Since I don't really see one, you could also use one of the square-head screws attaching that metal mounting strip to the box. Above all, the ground wire just needs to have a solid electrical connection to the metal (I am assuming here that since I don't see a ground wire entering the box, there is metal electrical conduit serving as a ground connection back to the main panel).
Live/Phase & Neutral
Common wiring practice in North America says that the red wire here would be the live leg and the white is neutral. However, it is always best to use a voltage tester to verify (with the circuit on and the bare ends of the wires safely away from other wires/boxes/hands/children/pets).
    I wouldn't use one of those square-drive screws for the ground - their one and only job should be to keep the light attached to the box. There should be a hole threaded 10-32 in the back of the box for the grounding screw. Since the wiring is in conduit, any color other that white or grey (neutrals), or bare, green, green/yellow (ground) is a hot. Some electricians will have a habit of making red a switched hot, but it's not required. Still, a +1 though!
    Jul 22 at 19:03
  • You're right about that screw - better to add another in the box than double-duty a mounting screw.
    – Chris O
    Jul 22 at 19:06
