I remodelling my cabin and removing a closet. The wood framing seems to be glued(?) to the concrete floor.
What's the proper way to remove the framing? Best idea I've got is a big crowbar but I wonder if I'll damage the concrete. Is there any magic fasteners I might be missing?
The concrete is, as far as I can tell, the last layer to the ground. Construction year is 1980-something, Quebec, Canada.
    Use a piece of small wood under the ply bar for protection if worried. If lucky by being careful, might even save some of the wood(don't count on it).
    Jul 22, 2022 at 15:39
  • I'd be inclined to saw most of the way through the wood near the fasteners, to encourage the wood to split there.
    – Hot Licks
    Jul 22, 2022 at 17:52
If you look closely, you'll see that about 10cm from the end of the board, there is an orange plastic thing that looks squished. That is the plastic collar from a powder-fired nail. Firing nails through sill plates is a common way to fasten wood to concrete.
You'll need to cut that nail and any others that might also be there. I would suggest a reciprocating saw with a bi-metal blade. You can squeeze the blade underneath the wood and slice that nail, along with any adhesive they might have used as well.
    Good catch on that nail.
    Jul 22, 2022 at 16:00
  • You can pull the wood up with a 36" prybar. The fasteners might come with it or pull through the wood and have to be pulled individually. Either way, expect a chunk of concrete to come up with the fastener, leaving a divot in the floor. The answer by @Chris O eliminates the divots and leaves the floor smooth.
    – RetiredATC
    Jul 22, 2022 at 17:12
    There appears to be another dirty circle (from the nose of the nail gun) about 10-12 cm from the wall, and possibly a 3rd even farther back, inside the left-right wall.
    Jul 22, 2022 at 18:15
