I am installing a wood railing post for an exterior railing and had planned to use the approach for fastening to a [new] concrete footing that is commonly used for deck posts. The post sits on a bracket that is elevated a couple of inches/few centimers above the concrete by a hefty steel screw that is embedded into the concrete when poured.
The tradesman working with me vehemently disagrees with this approach pointing out that a railing must withstand quite different - in particular shearing as a heavier person pulls on it - versus a deck post that must withstand primarily compression stress. The tradesman is concerned that a single bolt would not be sufficient to withstand the pulling on it.
I am still leaning towards the bolt embedded into the concrete due to the concern of rot when embedding the pressure treated lumber into concrete. It will rot.
So then - does the embedded bolt possess sufficient shear strength? I believe that to be the case but do not have a reference to back that up.
Note that there are mixed results when doing a web search for:
should I encase the railing stair post into concrete
The first two results I found resulted in a "split decision" on the choice.
So, is my preferred approach of using the bolt going to be safe for that pro football player grabbing onto the railing? Or do we sacrifice some longevity of the structure by burying the post into concrete so that it's definitely not going anywhere today.. but conversely will definitely be suspect in a couple to several decades?
9
  • Wood will rot if not maintain. Well maintain/protected wood will last for years. A post/pin in the centre of piece of will reduce the shear strength quite a bit compared to the full section of the wood. Most safety concerns are not what you will do, but what a drunken idiot will do on your land.
    Jul 18, 2022 at 10:37
    Your tradesman is confused. Pushing and pulling on the top of a railing does not impose significant sheer force on the at the bottom end of the post. It's a bending force you see there. Sheer is what you would see if you sat down on the deck and push directly against the bottom of the post where it meets the deck - and you'll never apply much force that way.
    – brhans
    Jul 18, 2022 at 14:41
    @brhans The terminology [/confusion?] is mine not the contractor. He described the forces but did not use the term "shear". Apparently "bending" is correct - glad to be corrected here. Jul 18, 2022 at 14:43
  • How is the lifespan due to rot not dependant on how much (gloop) the wood was soaked in? Jul 19, 2022 at 17:50
  • @RobbieGoodwin Noone said it is not. Do you have specific info/recommendations about the preservatives? I've seen "mixed reviews" on supplementing pressure treated external ground exposure rated posts with additional protectants: some say to do so in the ground/concrete portions. Jul 19, 2022 at 17:57
4 Answers 4
17
Here is a different concept, based on the vinyl fencing options where gates are going to be in the fence: at the gate posts they have metal inserts that are the same full length of the plastic post, go inside the plastic, and provide the real strength for the gate.
Use a steel post as a skeleton for a hollow wood cover post. The wood would only be the length of the visible railing. The steel post would go as deep as required into the concrete, and be almost as tall as the wood railing post.
Embed the steel post in the concrete instead, and treat it for anti-rust protection. Then set the hollow wood post over the steel post and fasten it towards the top, to not weaken the bottom of the steel post.
No football players will bend the underlying steel, and the wood cover completes the deck's look.
wood post over steel post
(picture from: https://www.doityourself.com/forum/fences-posts-railings-gates/520417-wood-sleeves-over-metal-posts.html)
11
    For shear strength that idea should also put a sizable dent into a car. Should be no worries about a drunken linebacker knocking it over.
    Jul 18, 2022 at 12:22
    @WestCoastProjects That price is for already made 4x4s. Can pick up a plain 4x4 and have a guy(wood shop) drill it out or buy a couple of 2x4s and hollow out the centres with a router or saw. This is a DIY site, not what to buy site.
    Jul 18, 2022 at 14:06
    @crip659 What to buy vs crafting a part by hand is part of doing it yourself when we have both time and cost constraints. I am doing the work myself here just do not want to spend too much doing it. I'm not comparing the price of item X at Amazon vs Home Depot but rather noting that a certain approach is generally much more expensive. This is not only a reasonable consideration for a DIY but an important one. Jul 18, 2022 at 14:12
  • 10
    You don't buy a couple of 2x4s and hollow them out - you buy a couple of 1x4s and and a couple of 1x2 and screw them all together (and careful inspection shows this is how the post in the picture is made too). Jul 18, 2022 at 15:41
    @FreeMan, picture credit added Jul 18, 2022 at 16:37
12
You could try using a different type of bracket, like the ones shown below.
A post bracket: a square metal bracket with some through holes, attached to a base plate
The bracket is attached to anchor bolts, either set in the concrete, or with expansion sleeves in drilled holes. The wooden post is inserted into the bracket and secured with screws or bolts. You could leave it floating an inch above the base plate to prevent rot.
There are similar ones that can be cast in place. See for instance this video at 1:20.
  • Curious to learn why you're not going with the cast in place ones from your own video.
    – SQB
    Jul 18, 2022 at 14:22
  • Thank you! OP was stuck on making it "1 bolt". They also make 4-bolt varieties that conform to the 4x4 footprint, though 6x6 is an option. Jul 20, 2022 at 1:16
  • Keep in mind these alone are unlikely sufficient to support a railing post. IRC requires railings to sustain 200lbs of force at any point along them, which is at minimum 36" high. 200lbs at 34" of torque puts an enormous force on the fasteners affixing the post to the bracket, and can rip the post right out, if not the first attempt certainly after some wiggling first. Jul 20, 2022 at 4:51
After further thought I do want to either bury the post in the concrete or at least have it laid flat on the surface.
In this case how can we retard the rot? Some recommendations I have seen include:
  • placing six inches of gravel at the bottom of the post hole before pouring the concrete. Allows seepage of water How to Protect a Wooden Post from Rotting in the Ground enter image description here
  • further treating the lumber
  • Using a sonatube and raising the footing several inches above grade. I am going to use an 8-inch diameter tube and do a 20 inch pour: 4 inches above grade and 16 inches below.
Older Answer
This is only a qualitative answer but I'm likely to go with it. I'm fairly convinced by this J-Bolt for which the J provides significant additional shear strength.
Taken from this video: Options for Fastening Deck Posts to Footings
    Similar terminology issue here in your 'Old Answer'. The J provides no sheer strength at all to this method (and it doesn't need to). It resists the bolt being pulled out of the concrete by tension - and even that is only to prevent the entire railing being lifted straight up. Preventing the railing from falling over when your pro football player leans against it is up to the bending strength of the bolt and the compression strength of the concrete it's embedded in (and has nothing to do with the J on the end).
    – brhans
    Jul 18, 2022 at 15:27
  • @brhans Fair enough. I read the J has the most effectiveness against uplift such as for covered decks (wind lift) (is that called a pergola?) Jul 18, 2022 at 16:01
  • @brhans: and don't forget, also the strength of the attachments holding the wood to the bracket. Jul 20, 2022 at 4:53
  • Posts that support a deck can be railing posts, because they'll have multiple 3/4" bolts into an edge beam and the two outer posts also have bolts into rim joists, holding the whole thing square, with the other end +4' in concrete. That link, way above, isn't going to be any stiffer than a fence in my mind (which is what it's to; a fencing company).
    – Mazura
    Jul 20, 2022 at 6:43
  • If it's a railing then it definitely needs to not go anywhere. "cheap, easy, good. Which two would you like?" - "Good quality, then moderation / balancing of price and effort" - that's a pressure treated 4x4 in a 10" or larger sono tube, at 3' depth plus w/e your climate demands. 8" tubes at 16" ? Frowny face.... If there's a right angle kink to it, maybe that's fine. If not, that isn't.
    – Mazura
    Jul 20, 2022 at 6:44
Use a concrete spur post
Wood will definitely rot at ground level - there's no question about that. So take steps to not only keep the structure intact when it does rot, but also make subsequent repairs easier.
Concrete spur post
Attach a spur post to the lower section of your wooden post, with 3 bolts through the holes as shown. Both the wooden post and concrete spur then go in the hole, and are concreted in place. You end up with about 50cm of spur below-ground and 50cm (the half with the bolt holes) above-ground.
Eventually the wood will rot at ground level, but it's firmly bolted to the spur so it still can't go anywhere. The wood above ground level remains sound, the spur is strong enough to stop a truck, and 3x M10 steel bolts will hold a lot, so the structure remains solid. And when (eventually) the post completely rots and needs replacing, all you need to do is bolt the new post to the concrete spur. The rotting remnants of the old post are still set in concrete, of course, but you can ignore them.
If you really wanted then you could even start with the wooden post slightly above-ground so that it doesn't rot off at ground level in the first place. This tends to cause problems with balancing the post-and-spur assembly when you're setting them in the ground though, so generally it's easier just to add 50cm to the post length you want and have the bases of the post and spur flush with each other.
Hint: You're much better using hex-head bolts instead of coach bolts into the wood, because you can't ever do up a coach bolt tight. Also use washers both sides to spread the load on the concrete and on the wood.
  • This still has the wood below ground and encased in concrete. I don't see how this prevents rot or even how it makes it easier to repair after it rots. You still have to get the rotten wood out of the hole, remove the concrete around the "spur post", remove the bolts (embedded in the surrounding concrete), then line up and through bolt a new post, then concrete it again, knowing your going to have to go through the same thing in another x years...
    Jul 20, 2022 at 13:23
  • "...You still have to get the rotten wood out of the hole..." You don't have to, because it doesn't matter. Just leave it be. And I'm not sure why you think there are any bolts embedded in the concrete - as I said, the top half of the spur post (the half with the bolts) is above ground. You simply rest the new post on the ground (on the ground-level remains of the old post that rotted off), drill 3 holes through the new post in line with the holes in the stub post, and bolt it back up.
    – Graham
    Jul 20, 2022 at 15:04
  • Both the wooden post and concrete spur then go in the hole, and are concreted in place." You're still putting wood in the ground. I don't see why. On my initial reading, I understood that the whole concrete spur post was to be buried. I guess I read that wrong. Still doesn't make sense to put any wood in the ground with this method.
    Jul 20, 2022 at 15:31
  • @FreeMan Like I said in the second-to-last-paragraph, you could keep the wood entirely above-ground if you wanted - but the weight of the post is off to one side of the spur, so it's always unbalanced to that side, and that makes it hard to set up in the hole. Sure you can work around that (wedge it in the hole with old bricks or something), but it's much easier to have the bases of the post and spur level. Then it sits flat at the bottom of the hole and doesn't want to fall over (or not more than any regular post anyway).
    – Graham
    Jul 20, 2022 at 15:49
