My ceiling fan has a speed control wall switch that slides from Off->1->2->3-4 corresponding to different speeds. However for some reason 1 is the fastest speed and 4 is the slowest speed. I'm guessing it was wired incorrectly. Is this something I can fix in a straightforward way myself?
1 Answer
Actually, there is a technical reason why many fans are Off->High->Medium->Low instead of the seemingly more logical Off->Low->Medium->High.
The short answer is: motors need something special to get started, and doing that on the high-speed setting is more reliable.
For the long answer, watch this video.
As to whether it is possible to change it, that depends on the design of the switch. A possible "maybe".
Think it might also be do to the size of the diameter of the fan blades. 20 inch box fan is high to low, while 10 or 12 inch fans are low to high.– crip659Jul 18 at 11:32
