I am replacing a fan-coil thermostat. Unit itself is Wito ultra-s 06-2t. Old one was wired and installed by an electrician, quite some time ago. I dismounted the old one and wanted to replace it with the new one, but it appears that there is a "COM" contact on a new one and nothing similar on the old. I'm quite inexperienced in wiring so I'd like to find out:
- Whether wiring a COM is required for the thermostat/some of its features to work
- Whether ignoring COM contact is safe
- Whether there is any wire in the current setup (probably, one of the blue ones in the N slot) that should go into the COM contact
Old:
New:
