I've got a 55" water barrel with the fixed lid and I want to prepare a small plumbing system that ideally uses gravity to provide the water pressure with one small caveat.
I would like a bronze or stainless steel spigot that I can install onto the barrel, and I would like it to have a standard garden hose end. This is the easy part and I have identified this model that I like:
From this spigot I know I can thread a water hose to it, but from there I get a bit lost.
I would like to create a PVC system that would feed a sink, a toilet, and, our Coleman Hot Water On Demand with Shower head. The Coleman Water Heater has a pump that I would like to use to make sure we have enough water pressure, but the pump's intake has an odd size, and even if I hooked it straight up to a garden hose, I don't think it would fit.
Here's a stock photo of the pump that came with the water heater:
I believe the pump can be submerged, but I would like to hook straight up to it. I'm just not sure what the thing is called that would have threads that I could attach this pump to from our barrel > spigot > hose > ???? > water heater pump.
Any suggestions?
for you. It may take more than one piece, but eventually, you'll get from Garden Hose Thread to "pump thread".
