I need to know what I need to connect the green/yellow wire to. There is no box in the ceiling to ground it to. Please help. I can email or text pictures if needed. Thanks in advance.
    Post your pictures to imgur then post a link to them here and we can edit them into the post, or simply hit edit on your post (it's at the bottom left), then use the "mountain and sun" button in the editor to add them Jul 12 at 2:17
You will need to install a fan rated box in the ceiling and connect the cable/BX to the box with the appropriate connectors. If NB cable with a neutral, connect the neutral to the box and then to the fan bracket. If BX, then the metal sheathing should be grounded and will ground the box when connected to it. If there is no ground then just leave the green/yellow wire unconnected and stuffed into the box.
-2
If you do not have a Ground wire coming to your ceiling box, leave the Grn/Yell alone.
Just put a cap on it.
Grounding is to protect people touching appliances with electric fault, where the hot wire touches the housing.
@Jack
  • I know what the grounding is for but the OP might not have a grounding wire up there so just leave the fan ground unconnected.
    – JACK
    Jul 13 at 13:55
