I have 7 raised garden beds with irrigation setup. Irrigation consists of a 100w solar panel going into a 120w max Controller. This charges 2 12v DC batteries connected in parallel. The batteries are used to power a 400gph water transfer pump which pulls water from my rain collection system when manually connected.
I have been trying to find a DC timer (as AC is not available and an inverter would kill the batteries) that will automatically turn on the pump at a set time then turn it off after a set time frame has passed with at least 2 on/off per day.
Does anyone have any suggestions on a timer that I can use for this purpose? It will be located outside but can be installed in a element tight enclosure if needed.
Any assistance is greatly appreciated. Thank you in advance.
