We are going to be remodeling our home and there are several walls I want to remove. All of the ones in the blue rectangle enter image description herele on the attached document. Is there a way to tell from the blueprint if they are load bearing?
    Hard to tell with a small section of the house. The only wall that looks close to being load bearing is in the yellow section of the plan. Most load bearing wall/s tend to run down the middle of a house in a straight line.
    Jul 2, 2022 at 0:36
    The easiest way to tell if a wall is load-bearing is to look at all the things above it. you're not making it easy.
    – Jasen
    Jul 2, 2022 at 4:30
    There's not enough information in that drawing for anyone to tell you with any degree of certainty which, if any, of those walls are structural or load-bearing. If would help to know what's above that space. If you tear all the drywall off then looking at the structure of the walls themselves would help a lot, as would tearing the ceiling down ...
    – brhans
    Jul 2, 2022 at 22:46
