Recently had quartz countertop and backsplash installed and there had to be a joint in the backsplash. Whatever was used to adhere the joints, (caulking or sealant) was carelessly wiped across the backsplash in several spots and dried to a thin,milky film. I used a razor blade they left behind to remove excess product that was raised but there remains these areas obviously still with a coating on it. What can I use to safely remove this film of their product?
    Photos would help, different caulks/sealants can be dealt with in different ways. Also you might try the ideas in this related question Commented Jul 1, 2022 at 18:40
  • Try wetting+soaking with different solvents and wiping with a towel. You can smoosh a wetted napkin onto the vertical surface to hold the solvent against the face for 5-10 mins before wiping. I would hit it first with 70% isopropyl alcohol, then if needed try other solvents in order of vinegar, lime-away, acetone, and naptha (zippo lighter fluid).
    – dandavis
    Commented Jul 1, 2022 at 19:30
    Why not call the installers back and have them fix the mistake on their dime? It was a poor installation job, they should fix it!
    – Milwrdfan
    Commented Jul 1, 2022 at 22:51
  • Agree try a few different solvents. If you go to an auto-parts store, they have a special chemical made to remove RTV gaskets (your caulk might be RTV).
    – Kyle B
    Commented Jul 2, 2022 at 5:16
    Do NOT use any chemicals, you might damage your quartz top. Use the razor method.
    – Traveler
    Commented Jul 2, 2022 at 6:09
They already left you the best tool for that
4 Inch Razor Blade Tile Scraper
But the blade needs to be replace every so often.
razor blade
A old used razor blade would not work, so replace it !
Source: Amazon
Just make sure you always hold it flat to the surface of the counter top, and not more the 45 dgr
10
    What makes you think this would be any more effective than the razor blade the OP already used?
    – brhans
    Commented Jul 1, 2022 at 19:27
  • @brhans his razor blade was already used, and not sharp enough.
    – Traveler
    Commented Jul 1, 2022 at 19:33
    You need to apply some pressure so the blade doesn't ride over the caulk, and doing so is easier when the blade is in a handle like this. You need to change the blade frequently. Buy a box of 100 from Amazon, it costs less than a tube of caulk. Using the leftover blade from the installer that he probably shaved with before he arrived won't get you results. I wouldn't use 4 inch, I'd use smaller ones but you can experiment to find the tool you like.
    – jay613
    Commented Jul 2, 2022 at 3:27
  • The razor isn't going to work unless the surface is "perfectly flat".
    – Kyle B
    Commented Jul 2, 2022 at 5:14
  • @KyleB so what would you recommend to do in this case ?
    – Traveler
    Commented Jul 2, 2022 at 5:57
