I have a basement hallway with a 4 way light switch configuration as follows:
- 3 switches
- 2 lights
Trying to replace one of the switches with a gosuna wifi light switch, but can't seem to figure out which one to replace (doesn't matter) and the wiring. In addition to them ALL having green (ground) wires, here are the wire color configurations (& pics) of each one
- switch #1 = red, black, white
- switch #2 = red, black, white
- switch #3 = white, white, red, red
The gosund wifi switch has a white wire coming out of it along with 3 available "hole connectors" for wires labeled "traveler1, Live, traveler2"
I tried replacing switch #1 with the GoSund. The hallway lights worked, but only with switches #2 & 3. The GoSund wifi switch didn't work at all.
Any ideas which switch I should replace and the wiring?
Here are the pics
