I have an AEG F55310VIO dishwasher (manual). I noticed that the top rack wasn't cleaning well, and started doing some investigation. I was surprised to see that several of the spray arms ports were clogged with what looked like old food. Some of the particles were about the size of a kernel of corn, way too large to fit through anything other than the water inlet for each spray arm. There was also a lot of particles.
I followed the water feed back, it looks like the water for the spray arms is sourced near the grey water filter. I also pulled the filter out, and it still looks to be in good shape. There are no holes in the mesh. That leaves me with two questions. Does the dishwasher rinse the dishes with post-filter grey water? If so, how did the food particles get through the filter?
  • Some of the larger particles could be built up over time.
    – JACK
    Jun 26, 2022 at 13:03
    All your questions answered in this video of a dishwasher actually working, with glass walls. youtube.com/watch?v=_rBO8neWw04. And that stuff is "black water" not grey water... since it contains food materials and bacteria (the latter comes from all the reasons we refrigerate and/or cook food we plan to eat, making it similar in human hazard to toilet water). Grey water is only laundry and shower, and possibly bathroom sink. Jun 27, 2022 at 1:28
10
Yes. The dishwasher fills the bottom basin with water (and heats the water to a good bacteria-killing temperature) then pumps the basin water to the sprayers. The dirty water falls back down into the basin where it is reheated and pumped up again. The dishwashing detergent helps get the dirt off the dishes and keep it in the water. The dishwasher empties and refills the basin several times during the whole cycle, so the spray water gets progressively less dirty. Eventually, by the final rinse, the water is clean enough to leave the dishes clean. (The fact that the dirty water is used to wash the dishes can be why the dishwasher instructions say to pre-rinse the dishes of major food pieces before putting them in the dishwasher. Then the spray water won't be as dirty as un-pre-rinsed dishes would make it.)
There's a hole. Somewhere. Or the unbroken filter mesh hole size is enough to stop green beans, for example, but not corn kernels.
My old dishwasher had an open basin, a grid-work cover over the pump sump, and a filter in the sump whose mesh hole size was large enough to allow corn kernels through. The pump shaft extended through the filter and had a 'shredder' (a piece of stiff wire) on the end which would smash up larger food pieces that got through the grid cover. We'd get corn kernels and peas in the spray arms all the time. (I guess we weren't pre-rinsing the dishes enough.)
My newer dishwasher has a large filter plate over the whole basin with much smaller holes. We also are pre-rinsing the dishes better. Haven't had clogged spray arms in a long time.
