I am looking to add a 240v 50amp outlet to my garage for charging the EV. With the help of folks on this forum I found that I need to expand my subpanel to add more breakers before adding a line to the garage.
I have a main panel (200amps) and a sub-panel (100 amps). They are both full. Can I replace four 15amps breakers with 2 multipole breakers to open two slots in the subpanel?
Here is what the main panel looks like:
On this subpanel can the slot #3 and #4; and #6 and #7 be merged with multipole breaker? If yes, I can bring two circuits from main panel to this, and use the main panel's two open slots to add a 240v 50amp circuit. Will this work and be safe?
If not, is upgrading the subpanel the only other option?
Thanks for all your help!
Here is the picture of the subpanel breaker from bottom. Shows the brand.
Here is the outside main panel.
