I’d like to do something to my spiral staircases so I can separate my second floor and first floor with a door or something. The reason being I don’t want my pets to go downstairs as we use our first floor to run business and second floor is our living area. Anyone has any idea? Much appreciated.
2How much do you want change the look? To block a stairway from pets, will need a door with walls. Where the picture is showing, will need at least two, maybe three walls, so a door will stop pets. Pets are like kids, if there is an opening they will go though it.– crip659Jun 23, 2022 at 19:35
2I'd be fond of a rotating fan type of device. Collapse when closed, extend and tension fabric when open.– fred_dot_uJun 23, 2022 at 20:13
4@fred_dot_u Something like the iris on stargate?– crip659Jun 23, 2022 at 21:07
1You'd need four gates because your railings aren't to code. If you brought it up to code and actually safe, then you'd need a single pet/kid gate, which is available at the store.... I thought this was going to be about stopping air flow, for which you're SoL anyway afaik. - Four gates and a crap load of big ass zip ties. Or four grand in railings, one gate, and a few zip ties.– MazuraJun 23, 2022 at 22:53
2It is a hole in the floor, where anyone can fall into from all sides– asinineJun 24, 2022 at 3:56
1 Answer
Well, here is my idea.
Very elegant, with 100% closing up the hole.
It works like a Folding hand fan.
You probably need 4 fan slices, so when fully open it wont interfere with passing true.
Here is the side view
You can also go cheap, and DIY stile, cut a cloth per hole dimension. Make one rotating flange (out of wood), attach a rod to it and fix it on the other end.
How to make the flange? Take a pice of play wood and drill a hole in in in size of the center post (probably 2- 3 inches). Cut in in half, now you have 2 halves. Screw in the rod.
How would you open and close this from below as you're climbing the stairs? Jun 24, 2022 at 6:06
@manassehkatz-Moving2Codidact >> Glad you asked, a stick in vertical position mounted on the first slice.– asinineJun 24, 2022 at 6:12
