I got overzealous when I put a new plastic check valve on my condensate pump. I tightened it too much and the check valve snapped off from the threads.
Is there any way to take out what's left from the check valve out of the condensate pump? Or do I just need to buy a new condensate pump?
I looked at the underside of the pump and it does not look like I could easily get to the bolt from the inside of the unit.
