This place I've moved into has a door that rubs each time, it seems the frame isnt square.
Is there a way to adjust the UPVC hinges to compensate?
the door hinge with the door open
the door hinge with the door closed
  • Is this a place you own or rent? If you're renting, call maintenance / the landlord.
    Jun 22 at 17:10
There are 3 types of UPVC hinges.
You seem to have the Butt Type.
While the other 2 are adjustable the Butt Hinge is limited to none.
Remove the cap on top and bottom of the hinge to find out if there is a adjustment screw inside.
butt hinge
  • Are you sure that the hex-head bolt you've highlighted from the OP's pic isn't the adjustment itself? It appears to have 3 marks on it, and there's one on the hinge. Looks like giving that bolt a little turn may cause adjustment of the hinge. OTOH, it might just loosen the hing from the frame...
    Jun 23 at 13:21
  • Thanks. I'll have a go of this at the weekend. I appreciate the help and input from you all. Jun 24 at 15:19
