I need to fit some edge trim to various bits of furniture board in my camper van.
This is the correct router piece:
https://www.amazon.co.uk/Trend-Slotting-31-8mm-diameter-C143AX8MMTC/dp/B0052XR3BY/
Bought, ordered, on its way.
Now I need a router. But almost all I look at are either 1/4" or 1/2". I can find ONE by Makita that says 8mm on it:
https://www.screwfix.com/p/makita-m3601-900w-8mm-electric-router-240v/3179r
I've never used a router before, I've no idea if it's like a drill, and the chuck is infinitely adjustable up to its maximum size.... or if I NEED an 8mm router to go with an 8mm bit. If so, how come loads of people seem to make 8mm bits, but I can only find one make/model of 8mm router?
Thank you!
