I have recently bought a new shed and opted to not have the installers fit guttering thinking that I'd do it myself (c'mon, £200 for a bit of guttering is a bit steep!).
I've gone and bought some Floplast Miniflo guttering that is designed for sheds and smaller structures as it has a smaller 76mm diameter.
Getting it back home, I can now see that after mocking up the fit of the guttering, it appears that the roof extends further than expected and would miss the guttering completely. I approximate it to be between 30-50mm out.
Is there a way in which I can make this fit? Or would I be best returning the guttering and buying the regular sized stuff?
FYI - The shed walls are made out of 12mm T&G with substantial framing inside.
