The title says it all. If plastic or fiberglass is allowed by code, what if any cons would there be?
Is it for indoor or outdoor, is it flash mounted or box.– RuskesJun 19 at 1:43
Answer to the title is check your local codes.– MazuraJun 19 at 1:44
indoor. I don't know what flash mounted is but it will go into a gyp wall so the outlet face is flush with the gyp, approx 8" from the breaker panel– MilkyTechJun 21 at 13:26
1 Answer
Same cons as any application of a plastic box .vs. steel - not as sturdy, not as good at containing arcs and preventing a fire. Sturdy may come into play quicker with a 14-50 since the plug/unplug forces are considerable.
Code is a minimum, and barring location in an area with stricter modifications, to USA NEC a listed box of adequate size is allowed, for the most part. Some areas (or occupancies) do not allow plastic, but if plastic is allowed it's not generally limited to a particular size of outlet (but the box has to have suitable entrances for the wire/cable/conduit being used. And it does have to be of adequate size for "box fill" based on number and size of wires, and devices connected to wires. That takes a big box for wires typical of a 50A circuit.)
