I am having trouble knowing what type of electrical boxes to use on smaller metal studs.
I recently purchased a new construction that has an unfinished walk out basement. On the three sides of the house that are underground they used these walls that, as far as I understand it, are prefabricated with concrete, insulation, and metal studs. Here is a sideview of the wall where you can see all three sections.
The problem I am facing is that the metal studs are not very deep, they are a little more than 1 1/2" deep.
I found some low profile boxes which I think would do the job. I just need to run outlets on these walls, nothing fancy. I was concerned because I saw in the reviews of this box that this did not have the cubic inches needed to meet some NEC safety requirements and was wondering if there was someone on here with more knowledge than me that would be able to confirm or deny that this is what I should be using. Thanks!
