For some context, I am planning to move some workshop tools into a storage unit.
The unit manager says that the maximum amperage on the outlet is 30A, and that they're wired for 120V. I was told they could re-wire the outlet for 220V to suit my needs.
The machine I'm looking at is 3 horsepower, which at 220V tells me that it would be suitable to run on a 15A outlet.
The technical specifications for the machine suggest running it on a 30A circuit. This would make sense to me, but only if it were a machine running on 120V.
Power-wise I would believe that a 120V/30A outlet converted to be 220V (and presumably ~15A) would be sufficient for this machine, but the specs have me scratching my head and believing I am missing some piece of information.
My question then, do power breakers only really care about amperage, and if I were to have the unit manager get an electrician to re-wire the outlet to be 220V, it would still have a maximum amperage of 30A despite doubling the maximum wattage? I.e. could I run my 3hp 220V machine on this outlet once rewired?
