I am in the process of tracing all home wiring. I am down to one switch box. The box was covered with a plate. Inside the box are 4 black wires, three white wires, one red wire, and ground. One of the blacks is a pigtail capped. The red is capped. The blacks are all tied together. The whites are all tied together. It seems like this was at one time a switched outlet that they disconnected. but I don't know. All this comes from one two wire and one three wire. Any advice for how to figure out what outlet was switched and how to wire it?
2How about a picture of he box.– JACKJun 17 at 3:19
1one two wire + one three wire = 5 wires. 4 black + 3 white + 1 red = 8. 8 <> 5. Something is missing in the description. Pictures please.– manassehkatz-Moving 2 CodidactJun 17 at 3:23
I’m guessing you have two /2 cables and one /3 cable. The red wire in the /3 cable isn’t being used. Anyway. It’s a junction box now. If you want to find out where all the wires go, you’ll need some tools. What tools have you got?– RibaldEddieJun 17 at 4:05
@manassehkatz one of the blacks is a pigtail.– Harper - Reinstate MonicaJun 17 at 4:26
@Harper-ReinstateUkraine I suspect that's the case, but it really isn't clear.– manassehkatz-Moving 2 CodidactJun 17 at 4:30
Switch the breaker off. Install a switch and attach the switch terminals to the black pigtail and the red wire. That should reactivate the switch except.
You will need to learn what "tabs" are.
And then you will need to open up receptacle(s) around the room and look at how they are wired. Look for receptacles that have a red wire attached to the receptacle (not just passing through) and whether it has a black wire also. If it has both, look to see if the tab is broken off.
It happens all the time where novices replace receptacles (e.g. right before a house sale), and don't know anything about tabs and fail to break off a tab that needs to be broken off. This renders the switch inoperable. I could see a frustrated novice then removing the inoperable switch so they didn't need to explain to the buyer why the switch doesn't work.
To make the switch work again, you'll need to find ALL the "shoulda been broken off" tabs. Even one left on will break the switch.
By definition, a switch that needs its tab broken off will have wires on both screws (or the backstabs right next to the screws).... I suspect they will be different wire colors.
Don't just break the tab on every receptacle with both screws populated. Most of the time, the receptacle is simply being used as a splice block and power is meant to go through the tab.
It sounds like it was a 2 or more switch box.
It also sounds like it even had some 3 way switches.
What was it switching, that is now under constant power, or switched from another location?
Maybe the plan was to have multiple lights in the ceiling that was abandoned.
It could also be planned for 2 or more wall outlets.
All of this could be simply answered by a picture of the box.
How to find out?
Disconnect all the blacks and something will stop working, under the assumption there was power there in first place. (Probably more of somethings will stop working)
Now connect them back one by one.
